Kohler Command Pro 23 Crankshaft Seals
Vettepiper
I've spent over an hour looking trying to find out if the crankshaft seals are the same part # for both front & back; all I can find just talk about the output end and not the flywheel end. Output end seal is pt # 25 032 06S. Does anyone out there know if both seals are the same. Thanks!
Scrubcadet10
Moderator
Staff member
Will need the model number to verify the parts look up but,
Vettepiper
Thanks for your reply - I can't for sure make this out(hate that I'm mentally declined). Looks like different seals but looks like same side of engine. Duh!
Scrubcadet10
Moderator
Staff member
The first one i posted , that seal goes in the crankcase / engine block, the 2nd seal (25 032 06S) goes in the crankcase cover which is probably the PTO/output side, depending on application.
