mechanic mark
- Jul 15, 2013
- Threads
- 175
- 7,491
LESSON LEARNED.....DON'T ASSUME.
I have owned several Broadmoors over the years, beginning with a 728 that I bought new and still own. So, this is a new to me Prestige with 37 hours. Regarding the deck height, I was focusing my efforts on the rollers and electric deck lift. I ASSUMED that the deck was set up properly front-to-back. I was WRONG. When I finally checked it, I learned that the front tip of the middle blade was actually over 1" LOWER than the rear tips of the side blades. When I set it up correctly with the front tip of the middle blade .25" higher that the rear tips of the side blades, I was able to achieve the cutting height that I was looking for. I made a mistake by thinking that the PO had the deck set up properly. Thank you to all!!!
P.S. I'm one of the ones that understands how Simplicity decks work!!
My sons & I own & maintain our 3 Conquest & 1 Broadmore Simplicity tractors with B&S Vanguard engines. Good to hear you figured it out.LESSON LEARNED.....DON'T ASSUME.
