grumpyunk
- Jul 13, 2015
- Threads
- 0
- 133
The increased purchase price of diesel engines in pickup trucks made them uneconomical unless the miles driven annually were high. Those who bought thinking they were going to save money may have realized the increased investment had a pretty long payback time before actually costing less than a gas burner.
I have nothing against diesel engines, but note that they were not as popular to buyers as the major pickup sellers found out.
I am referring to the smallish ~3.0l engines that were available, not the 6l+ size.
As far as doing a diesel conversion, it would likely prove to be a unsuccessful endeavor as the engine likely would not handle the increased compression and running pressures if they could be engineered in somehow, and design and installation of some sort of injection system would be difficult to say the least.
There are some horizontal shaft smallish singles from China that make a lot of noise and smoke, and will shake most equipment apart unless everything is Loctited that might be interesting to the poster for not a lot of money. They appear to be based on the Honda single clones with a lot of extra metal in the head/cylinder/block/piston/rod/crank to handle the increased pressures needed to operate as a diesel.
Might be a good fit for the 'mud motors' that hang off the stern of boats used mostly in shallow water. Lots of torque at low rpm is perhaps a good fit for a boat propeller.
tom
tom
