Kodie's Lawn Service
- Dec 27, 2012
- 705
2storkes are great along with 4 stokes when it comes to buy trimmers or a blower would u buy 2stroke or 4 cycle ???:thumbsup:
I prefer the Stihl 4 Mix units in both Trimmers and Blowers.
i love the 4 mix but it is still a 2 stroke with a 4 stroke motor design :thumbsup::thumbsup::thumbsup:
The 4 Mix is not a 2 stroke unit, the 4 mix unit is a single cylinder 4 Stroke engine with gas & oil Lubrication, Check the manual.
It maybe a 4 cycle engine but it runs on 2 stroke gas so there for it is a 2 stroke :thumbsup:
All of them will run on two cycle gas. It will just make them smoke a little and also might eventually foul the plug.
A 4 cycle and a 2 cycle engine are not the same thing however. A two cycle works off of a valve like a reed valve and only uses two cycles where as the 4 cycle has a seperate exhaust and intake valve and takes 4 cycles to operate.
If you try to run a 2 stroke off of 4 cycle gas you will seize the engine.
A two stroke lubricates from the oil in the mix. The four stroke lubricates from oil in the sump.
Well I'm not going to argue the point, you can define it anyway you want to make you happy but the fact remains the Stihl 4 Mix engine is not a 2 stroke unit, the 4 mix unit is a single cylinder 4 Stroke engine the same as the Honda trimmer engine or as any other 4 stroke engine, it runs the same. Whether it uses a sump as you say or runs with gas & oil Lubrication is of no consequence. It's a 4 stroke engine plain and simple.
