Fireman 123
- May 14, 2011
- 358
Can the same needle bearing that's used in the armature plate, also replace the bronze bushing in the lower end? Can these bearings, and seals be matched up at a local auto parts store vs. buying an over priced LB part? I realize the rod bearings, and rings will need to be specific. Just hoping to do this on a budget. Thanks for any response.
