Berniebac
- Apr 8, 2012
- 185
I picked up an 8 hp Roper and wanted to get it going. It is not rusted too bad but has spent the last two years stored outside. I cleaned the carb and fuel tank. Added a new fuel line and changed to oil. Now I want to test fire it.
So I hooked my power pack to the battery (dead battery) and tried to jump it. Had parking brake engaged, gear shift in neutral, and turned the key. Nothing happened, not even a click. My ignition switch is suspect as there is a lot of play in the key and how far the key rotates, goes past the start position. I don't want to rip anything apart just yet, without checking for a few more suggestion.
Anyone have any thoughts?
