Rough running LX178
tiger29
AFTER new carburetor new fuel pump runs like a new one did a lot of mulching in a week now it started running rough.
Running like new for a week after replacing the carb and fuel pump sounds promising. Did it run well the whole week, or was it still acting up now and then?
Does it run rough right from startup, or does it start acting up after it's been running a while? I'd want to know if it changes as it warms up before chasing anything else.
Have you done any testing on fuel flow? How is the flow from tank to fuel pump? If it isn't free flowing, take off the fuel cap, and find the fuel pickup with a flashlight, and fish out the pickup. They often have a filter on the pickup, that can clog up as the engine runs. If you pull the pickup off the line, you can backflush it with air or carb cleaner. Some have check valves, and they don't backflow. Get the filter clean. If this helps, you need to clean out the tank.
If flow to pump is good, check from pump to carb, and check the pulse line from pump to engine. Make sure it's a good connect. If there's any doubt, replace all fuel lines. They break down on the inside, so you don't see it. If they are hard, replace. It doesn't cost much. If you're replacing lines, do the filter too.
Tank has internal trash or fuel lines rotted internally where you and I can't see it.
For the whole week it ran like a new one. will do some more checking.
Runs rough from the start up ran well like a new one for a week or more.
Since it ran well for a week, I'd look at fuel supply before blaming the new carb. Could be trash in the tank or a fuel line coming apart inside. Let us know what you find.
The most common problem that I see on a regular basis is the fuel quality or dormant trash that is trapped in the bottom of the fuel tanks.
Carburetors do not run good for a week and then suddenly fail without reason.
The new carburetor will likely need to be disassembled and cleaned.
Also, consider other factors like a bad spark plug. Aftermarket cheap plugs are the worst offenders.
Thank you for your info! Did not do anything else the next day was running fine. If it happens again will let you know.
Then it does sounds like trash in the tank.
Item #4 is a choke point for tank trash and the mower is not running fuel back flushes it; unless, the item get wedged in it.
You be surprise what can find it way into the tanks. Recently I removed six caterpillars from one tank and the other had pieces of rubber from the fuel cap. This was CC Tank.
