Skippydiesel
- Nov 29, 2020
- 521
Slow leaks are when the tyre loses pressure over many days.
Mower tyres seem to be particularly prone to slow leaks. Small volume and lightweight construction, likly causes.
I am attracted to the idea of using one of the liquid "goop" repairs, to extend the time between needing to add air to my tyres.
Note: I check my Schrader valves and replace if they are leaking - very rarely the problem.
- Is this a good idea?
- If so, what goop do you recomend?
- If not, please explain?
