Interesting -Yes, most Kawasaki engines will use around 15-20ccs per hour.
you are right“ The "W" in 10W-30 stands for "Winter," indicating the oil's viscosity rating in cold temperatures. “
I would love to see the science behind that.Interesting -
My service instructions council that the use of synthetic oils will increase oil consumption.
I have always used single weight (30) mineral oils (getting harder to find & more expensive) and so far do not need to top up between oil changes.![]()
No science, just history from me - Single 30 grade/weight oil was the universally recommended oil for small motors for all but the last 10 years or so. Never had a problem with it.I would love to see the science behind that.
With all due respect, you need to brush up on your oil knowledge. Things have changed.No science, just history from me - Single 30 grade/weight oil was the universally recommended oil for small motors for all but the last 10 years or so. Never had a problem with it.
In fact multigrades were considered to be "to good" in that it was thought they might polish the cylinder bore causing excessive oil consumption even reduced compression.
Then the multigrade oils started to creep in, followed by the semi and then full synthetics. To the best of my knowledge there was never an explanation for this change. Some suggestion of synthetics being more stable at high temperatures - this may be true but does that make them better than straight 30? If better in what way? eg does your engine - deliver more power, last longer, cost less to run - I think not.
At least one of my service manuals, using an ambient temperature chart, recommended at lest 3 -4 diffrent weight oils, usually starting with 30 and ending with full synthetic 10W-50 (or similar) with the "Caution" that oil consumption would be higher with the full synthetic oil.![]()
You cannot run straight 30W in the Kohler Command series engines if you do the lifters will rattle.With all due respect, you need to brush up on your oil knowledge. Things have changed.
True my friend - Everyone has moved to the far more expensive synthetic oils - Why?With all due respect, you need to brush up on your oil knowledge. Things have changed.
