z335e will not crank. Tested brake, seat, handle safety switches and all fuses. Replaced starter solenoid and ignition switch but will not crank. The old ignition switch was definitely faulty.
If I pull up blade engagement button, the belt clutch engages when the key is turned. I don't detect 12V at starter solenoid when the key is turned.
