I have an intermittent misfire with this engine. Serial number is 406777, type is 0442 B1. I have replaced the spark plugs after setting the correct gap. I have checked the valve lash. The intake on the left cylinder needed a slight adjustment. The others were all at .05. I cleaned the valve covers and put on new valve cover gaskets. I made sure there were no vacuum leaks. I even replaced the fuel filter.
This started as a slight backfire, but now has become more frequent. This engine has a lot of hours, but I can't give an exact number because there's no hour meter. I've had this mower since 2008, and it's been relatively trouble free.
Am I now having carb trouble? I'm stumped.
