BackyardBrian
- Jun 17, 2025
- 65
Alright so a couple weeks in with the X350 and Im already down the rabbit hole of blade care lol. Cut looked a little uneven last mow and figured its time to pull em, sharpen, put em back.
Watched a bunch of vids and now Im more confused than when I started. Half the guys say just stick a screwdriver through the center hole, eyeball it, if one side dips down grind that side till it sits level. Other half swear you need an actual balancer or the vibration will kill your spindles over time.
Then I came across this blade balancer. Its magnetic, mounts on the wall, you set the blade on the cone and it tells you which side is heavy. Looks way more accurate than the screwdriver trick but part of me wonders if Im overthinkin it for a homeowner rig thats only cuttin 1.5 acres. Or should I just skip the whole sharpen and balance thing and drop a fresh set of blades on instead? Wanna hear what you guys actually do.
