I was going to start building it tomorrow since everything is cleaned up etc., but I looked it over carefully. On closer inspection, there is a crack running from the flaw in each direction. There is also another one that interescts it a little ways from it, so there is likely to be a bigger pocket under that area, like a sink hole. I checked to see if new engines can be shipped to California and the answer is no. HF might have some stock from 2024 they are still unloading, but I just went ahead and ordered a new cylinder assembly, and a piston assembly using a coupon to save a little. I can only pray that the tolerances will be in spec. Sometimes replacement parts are worse than the originals. I will be inspecting the parts quite closely for any flaws. Don't know if the governor arm will be already installed or if I have to pull it off the old one and use it on the new assembly. This is just not fun anymore.
Thank you all for helping. This mower has to last 15 - 20 years. The alternative would have been to drive 600 miles to buy a new gasoline mower out of state and bring it back. That would have been 30 gallons of gasoline at $6 a gallon plus oil, and wear and tear etc., plus the lost time. I am not interested in an electric mower or someone else's used mower. I should not complain - I got 20 years from it, and the cost to rebuild it will still be less than a new mower, which they have smaller engines now than this one. It's would be like going from a V8 to a flathead six. If we leave the state we'll take it with us. More and more that seems to be the only way to preserve one's finances. There are just too many people in this state that believe in using other people's money to live off of. Add to it the fraud, and the future is dismal here.
