vintagerust
Being 'dry' is sometimes part of the problem when it comes to corrosion. We used to soak the points with WD40 to displace moisture and stop corrosion. The oily residue protects the points and has no effect on continuity.
I do think that newer points are substandard to what came in most motors when new. I also don't think that the OEM boxed points from BS have been anything more than aftermarket points reboxed. BS hasn't manufactured those parts in three decades and they have likely just been sourced from China since the 1990's. Someone told me once that if it didn't come in an orange/blue box with BS on it, chances are it was sourced from elsewhere. They changed box design in the late 80's and switched to parts bags in the more recent years.
I gave up on points a number of years ago for these very reasons. The points covers were never water tight and simply washing the mower often lead to a no start. That's not a big deal on a push mower where as its likely going to sit and dry out for a week but on a tractor its not acceptable.
If you seal up the points cover 100% it leaves no way for condensation to get out either. The wire opening gets sealed, more to secure the wire than anything else.
I've used the Nova chips, and any number of knockoffs over the years with good results. Rarely have I had one fail. I think the only one I ever found to be bad was an OEM Kawasaki module on a JD mower.
