Craftsman push mower engine issue
Astager
NEED HELP with a craftman push mower w a Briggs engine model #126T02 date code of Jan 2010. Engine starts on 1st pull, runs fine for about a minute then sputters, sometimes stalls out or goes into like a "low idle" mode. If it stalls out a few pulls gets it going again but runs in a "low idle" mode. The mower will run "low idle" for about 5-7 minutes (it varies) then miracuslously idle up to normal operating speed and then runs great. The mower acts like this 9 out of 10 times.
Thought it was the auto choke, repaced that, still does it. So far I have cleaned the carb, new plug, new coil, new fuel line. This is a head scrather for me. Any thoughts or suggestions are greatly appreciated. I am at a dead end here.
Thanks
Photo attached for reference.
When you cleaned the carb, did you replace the float needle and seat? You must also reset the float level. I’ve attached a procedure I taught my students to follow when doing carb service. Hope this helps.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. Next check to make sure that the float does not have any liquid in it. If it does, replace. If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: On the side of some Tecumseh carbs you will find a plastic cover. Under this cover will be an idle jet. Remove it and check to see that the jet is open both horizontally and vertically. You should be able to push the old float needle wire through the vertical opening.
Thank you for the info, much appreciated!! I did not replace the seat or the needle when I cleaned the carb. I will get a rebuild kit and see how it goes.
Trash or moisture inside of a fuel can is the most common cause I have found for this problem.
Pull the upper cover and remove the fuel tank. Empty the tank then blow air back through the fuel line. These tanks are bad about blocking/choking up the fuel exit nipple.
If I am not mistaken, they have a small screen filter that is made into the tank outlet nipple. I recommend cleaning it with carburetor spray.
Do not punch through the screen or remove it unless to want to figure out how to install an inline fuel filter. There is very little room to install an inline fuel filter on this design.
Hi Rivets,
Plastic floats and needles on newer carburetors seldom have adjustments.
With the Briggs you replace both the needle and seat, which should get you very close to getting the float level. In my years I’ve figured out a way to adjust plastic floats, but I’m not going to post for all to see, as many DIY guys will not do it right and end up buying a new float.
I've watched some of the (novice) DIY guys in the past and it makes for good entertainment.
Thanks for all the input, rebuild kit on the way. I will repost w the results. Enjoy the weekend!
How about bugs and bug parts in the fuel tank? I’ve seen it where containers of gasoline had bugs go down the spout to their death. How about dirt dobbers?
I’m thinking it’s slow filling from tank
