DepDad
Heat gun on a fuel filterSpray with lubricant and use pliers and work fuel filter back and forth. Maybe use a heat gun if you have one.
… This is frustrating. It must be changed after THREE years - I know that. Ideas anyone???
chainsawnerds.com
I have a JD X-370 that is 3 yrs. old. I have always seen myself as pretty handy at 75, even though arthritis greatly affects my work these days. After a long string of lawn tractors - all of which I serviced myself - I got the JD primarily for the hydraulic power steering and overall quality. I love my X-370, and I have historically changed oil and filter, plugs, tranny fluid and filter, blades, air filter, greased, etc. This is going to sound crazy I know, but I CANNOT REMOVE THE FUEL FILTER!!! WHAT'S MORE, I HAVE NEVER BEEN ABLE TO REMOVE IT!!! It is inserted on both ends so tight, and so far, that the clamps actually serve no function. I can slide those down the gas line easily but pulling and/or twisting does nothing. I have actually thought about cutting the line to remove the filter, but what about the next time? I've also thought about getting out my ramps, loading the mower on my truck and taking it to the dealer, but that seems ridiculous. Lastly, I thought perhaps if I scored one end of the fuel line like every 1/8 in. deep all around it that maybe I could work one end of it out of the line. If I could get one end out it would make it somewhat easier to get the other out. This is frustrating. It must be changed after THREE years - I know that. Ideas anyone???
I feel your pain. Try using a pliers to hold the rubber line as you twist the filter.. A heat gun might help but be careful..Spray with lubricant and use pliers and work fuel filter back and forth. Maybe use a heat gun if you have one.
TON of great info preceding and 5 pages in I am reluctant to add but, old rugby player here; Who Can Resist A Pig Pile?!
First, I would drink my own urine (Ghandhi survived doing it, daily, in a real (actual) prison) before putting fuel containing any ethanol in anything we own , other than daily driver Toyotas and one RAM 1500. Even then, whenever any of those go into storage for more than a month; top tank off w non-ethanol and a dose of PRI-G*
Secondly, I never cease to be amazed at how often these little plastic doohickies come in not just handy but, to save the day; iirc I used the blue one, second in from the left on the 3 yo fuel filter on my 580:
(I wiped the posts of the new filter w a bit of Fluid Film (lanolin, another “wonder in a can”) before installing. Lanolin: 100 years from now that sucka is gonna slip right off, lol!
* - Lastly, PRI-G is not just a stabilizer (marketing term for does nothing more than “creates a film across top of fuel to prevent condensation from getting below it” - “Shhhh, that is, until you move or shake container, later (doh!)
And not just a preservative - PRi-G is a independent research lab-proven fuel RESTORATIVE used in petroleum industry, to include refineries …
EVERY small engine, boat, jet ski, and classic cars get doses of PRI-G regularly if not last tank fill at end - of - season …
Best of success!
Fuel Storage⎜Long-Term, Cost, Safety, Gas, Diesel, Kerosene | Country Homestead Living
Proper long-term fuel storage is something anyone can learn to do. Whether you are storing fuel for a generator, your chainsaw or other equipment. It…www.countryhomesteadliving.com
BatteryStuff Articles | PRI Gasoline FAQ and Dramatic Benefits
BatteryStuff Knowledge Base Article answering common questions regarding our popular fuel treatment, PRI for Gasoline. One 32 oz bottle of PRI will treat 512 gallons of fuel. It has both restorative and preservative properties.www.batterystuff.com
Pri G Vs Stabil Fuel Additives (3 Key Effects On Engine Life)
Discover how Pri G and Stabil fuel additives impact engine life. Explore their top 3 effects and choose the best for optimal engine performance and long...chainsawnerds.com
Review of PRI-G Fuel Stabilizer (Hands-Down the Best Available)
I had an opportunity this week to get my hands on a bottle of PRI-G fuel stabilizer, something I had been meaning to do for quite some time. For many, many years I've always used Stabil as my fuel stabilizer because it's what's been available locally. Sadly, PRI-G is difficult to find at times...rethinksurvival.com
PRI Fuel Treatment: Power Start, PRI-D and PRI-G
Keep your fuel fresh with PRI fuel stabilizer and conditionerwisementrading.com
These work well for me. They don't put any stress on anything but the gas line and filter.I have a JD X-370 that is 3 yrs. old. I have always seen myself as pretty handy at 75, even though arthritis greatly affects my work these days. After a long string of lawn tractors - all of which I serviced myself - I got the JD primarily for the hydraulic power steering and overall quality. I love my X-370, and I have historically changed oil and filter, plugs, tranny fluid and filter, blades, air filter, greased, etc. This is going to sound crazy I know, but I CANNOT REMOVE THE FUEL FILTER!!! WHAT'S MORE, I HAVE NEVER BEEN ABLE TO REMOVE IT!!! It is inserted on both ends so tight, and so far, that the clamps actually serve no function. I can slide those down the gas line easily but pulling and/or twisting does nothing. I have actually thought about cutting the line to remove the filter, but what about the next time? I've also thought about getting out my ramps, loading the mower on my truck and taking it to the dealer, but that seems ridiculous. Lastly, I thought perhaps if I scored one end of the fuel line like every 1/8 in. deep all around it that maybe I could work one end of it out of the line. If I could get one end out it would make it somewhat easier to get the other out. This is frustrating. It must be changed after THREE years - I know that. Ideas anyone???
Small bladed straight screwdriver or an oring pick. Insert between hose ID and filter, give it a drop of silicone spray or something slippery, let it sit for a minute, work the blade around the ID....I have a JD X-370 that is 3 yrs. old. I have always seen myself as pretty handy at 75, even though arthritis greatly affects my work these days. After a long string of lawn tractors - all of which I serviced myself - I got the JD primarily for the hydraulic power steering and overall quality. I love my X-370, and I have historically changed oil and filter, plugs, tranny fluid and filter, blades, air filter, greased, etc. This is going to sound crazy I know, but I CANNOT REMOVE THE FUEL FILTER!!! WHAT'S MORE, I HAVE NEVER BEEN ABLE TO REMOVE IT!!! It is inserted on both ends so tight, and so far, that the clamps actually serve no function. I can slide those down the gas line easily but pulling and/or twisting does nothing. I have actually thought about cutting the line to remove the filter, but what about the next time? I've also thought about getting out my ramps, loading the mower on my truck and taking it to the dealer, but that seems ridiculous. Lastly, I thought perhaps if I scored one end of the fuel line like every 1/8 in. deep all around it that maybe I could work one end of it out of the line. If I could get one end out it would make it somewhat easier to get the other out. This is frustrating. It must be changed after THREE years - I know that. Ideas anyone???
Look on Amazon for hose removal tool, I have one of these and it’s pretty handy removing gas lines, like some one said heat the hose where it attaches to the filter with a hairdryer or heat gun on low temperature then slide this tool between the filter and the hose and squeezeI have a JD X-370 that is 3 yrs. old. I have always seen myself as pretty handy at 75, even though arthritis greatly affects my work these days. After a long string of lawn tractors - all of which I serviced myself - I got the JD primarily for the hydraulic power steering and overall quality. I love my X-370, and I have historically changed oil and filter, plugs, tranny fluid and filter, blades, air filter, greased, etc. This is going to sound crazy I know, but I CANNOT REMOVE THE FUEL FILTER!!! WHAT'S MORE, I HAVE NEVER BEEN ABLE TO REMOVE IT!!! It is inserted on both ends so tight, and so far, that the clamps actually serve no function. I can slide those down the gas line easily but pulling and/or twisting does nothing. I have actually thought about cutting the line to remove the filter, but what about the next time? I've also thought about getting out my ramps, loading the mower on my truck and taking it to the dealer, but that seems ridiculous. Lastly, I thought perhaps if I scored one end of the fuel line like every 1/8 in. deep all around it that maybe I could work one end of it out of the line. If I could get one end out it would make it somewhat easier to get the other out. This is frustrating. It must be changed after THREE years - I know that. Ideas anyone???
