LarryJohnson
The old voltage regulator had this grey wire connected to the center mounting screw of the regulator, so I re-connected there when I replaced the regulator. It appears to be a wire coming from the ignition coil, acting as a ground wire for the voltage regulator. The regulator is mounted to plastic, not a metal surface. Is this where the wire is supposed to be connected. The battery wasn't charging before or after changing out the VR, but I"m not certain it's grounded properly.
