- Sep 7, 2024
- 3,501
This is a case of very poor engineering using materials that will fail. Constant overheating due to a very dirty engine has also compromised the head gaskets.
I don't completely disagree. New engines are not like the old flatheads. However, I think that if this engine hadn't overheated, and had been properly maintained, this wouldn't have happened, and it would still be running just fine. The crank (with rods & pistons connected) turns over smoothly, and the cylinders still have cross hatching. I don't think either of the head gaskets blew. They are the newer style. I'm replacing them anyway, and every other gasket and seal I can access.This is a case of very poor engineering using materials that will fail. Constant overheating due to a very dirty engine has also compromised the head gaskets.
Please explain what exactly was this overheating issue and how was it repaired?It ran for almost two seasons after I repaired the problem that caused the overheating.
The cooling fins were almost completely clogged with oily dirt. I bought the mower, fixed a few things that HAD to be fixed, then used it for a half season. During the off season, I did a more thorough service on it, and found the clogged fins. I had the engine off, so I cleaned the fins really well. It ran for almost two more seasons, so I thought I'd dodged the bullet.Please explain what exactly was this overheating issue and how was it repaired?
Yeah... when I saw the broken cam gear, I knew what caused it.It is all due to overheating. It makes the plastic gears brittle and will over time break.
