After you finish laughing, can someone give me a direction as to where to start!! This is my first carb clean on a larger carb. I have cleaned a simple small carb and it ran okay, I was just lucky.
Sorry can't get the video loaded.
I'm now having surging. I pulled the spark plugs, one is dry and clean the other is wet!!
After finding the mouse house, I replaced the coil ( chewed wire). This was done while I had the carb off.
So, new coil, adjusted valves, from .006 to .004 and took the carb off and ran it through the cleaner.
The carb now has a new float valve. I sprayed carb cleaner in every hole and all seemed clear of dirt.
