carb replacement or overhaul kit?
oldntired55
i am trying to overhaul this adjustable carb on a tecumseh 9hp snow king. this number is stamped in the carb body. is it a legitamate number? or a casting number? 1433J6X see attached photo, i think i found a kit on ebay. would the 7 ,8 and 9 Hp engines use the same kit?
That should be a Tec 632370A carburetor and the kit for its 632347. (PN correction from 962370A which was a typo on my part)
But verify post the engine model and spec numbers so we look up the engine.
just an update, i pulled the carb (also adjustable) from an 8hp tecumseh on an old snowblower, gave it a cleaning and tried it. same surging, same belching black smoke now and then. im thinking im missing something. gonna pull the fuel line at carb and check for good flow, make sure it is not restricted. update later..
Opps I made a typo on the carb PN it is 632370A not 692370A. Finger got on the wrong numeric key.
If closing the main jet stops the surging then the carb is flooding. Did you invert the carburetor and pressure test? It should hold 7-10 psi for 30 minutes or longer.
