- Feb 19, 2020
- Threads
- 120
- 12,825
Not all have the time to keep a manicured lawn. With that most mulch setups are terrible at cutting grass without clogging. The only dedicated mulch deck that been though my shop has been the JD Freedom deck.When you have a mulch kit that is properly designed and you know how to use it properly, they do a great job. Yes, you have to learn how to use it!! I’ve have the mulch kit on my 1996 Toro 16-38XL and have neighbors who actually ask to use it because of the way the lawn looks when finished. Only time I don’t like the cut is when I can’t cut dry or grass is too long.
But even normal decks on some models have discharge problem in heavy grass cutting [tall grass]. The worst I have seen have been on Gravely mowers. I have had shut the decks move to a cut area, raise the deck, cut off the deck, let the clippings drop, and then with the deck still raised re-engage it. It is a rinse and repeat as long you cutting heavy grass. Yet I can take a Super Z and knee high grass with minimum problems.
One key thing with mulching is to travel slower giving the decks time to clear the clippings and always cut dry grass.
