littlegman
Taryl made a video explaining the coil tester types. He said and I agree, the light bulb type does not give the full picture of coil performance. Taryl said to get the Briggs type or even better the PET-4000. He had a coil that would fire at low revs then crap out at mid and high revs. I've seen the same thing several times. Reason why I bought a PET-4000.
Thank you for all the tips. Mine kind of chugs a bit before coming to a halt, I believe it has to be the fuel because it will try to start with the choke on but will die out. After about 20 minutes or so, it will start again like there is no problem. I did change the fuel pump and filter but didn't seem to help. I replaced the fuel pump with a chinesee one off amazon and after I read to get that sometimes they are defective also. I do have a inline spark plug tester similar to the one in the other reply.Does the engine die suddenly like you turned the key off (electrical), or kind of chug a bit and come to a halt (fuel)?
