Frank Woodbery
 - Dec 18, 2020
- Threads
 - 3
 - 16
I  recently cleaned the carburetor on an FJ180V. I found that in reinstalling the carburetor it is difficult to snake it around the intake manifold and hook up the throttle/choke linkages. I also don't want to mess up the new gaskets. Is there a simple trick to completely remove the intake manifold first to gain access to the mounting location? This is the FJ180V with the flat air filter, not the cylindrical filter as is now used on the Kai engines. I am including photos including the engine ID tag to help explain below. Thanks in advance!
