Exactly(!) what I was thinking after reading the OP post on page one of 4. I jumped here to the end of four dang pages and find that, after all this posting, John posted the most likely answer! You got MY vote!I would find a diagram showing the correct routing of the belt and make sure you install the belt following the correct routing. Make sure the belt tensioner is working properly and the tensioner's spring is attached properly on both ends.
I do not have the same models as you, but my experience on my JD equipment is the tensioner springs often become unattached from the tensioner. When I install a new belt it commonly seems too short and is a bear to get installed correctly. After some use the belt stretches and becomes easier to install.
Is there any chance you may have lost the tensioner spring for the snowblower's belt when removing the snowblower and storing it for the summer?
