Hello. 5 acres of former cow pasture in South Central Texas. Mostly native grasses, but will seed turf at some point. Soil has a good bit of clay and is pitted from hooves, so it is not smooth. Most flat, but a couple ditches/swales.
Looking at the Patriot and lower levels based on budget.
Seems like buying based on transaxle might be smart from a value standpoint.
The 52" Patriot has the ZT3100 and the 61" Patriot has the ZT3400.
The Freedom and Liberty lines mostly have the ZT2800, *but* the 61" Liberty has the ZT3100 (and the Ogura GT2 108ftlb clutch)!
Spindles are all aluminum with sealed bearings. All have Hero decks.
MSRPs:
The Patriots with the ZT3100 are about $9k.
The Patriots with the ZT3400 are about $10k.
The 61" Liberty is about $7k
That's a difference of about $2,000 - $3,000 for the upgrade to Patriot models, which have the suspension seat, bigger tires, 0.5" higher max cut, foot lever parking brake, and 1 gal bigger gas tanks.
It seems to me that the 61" Liberty is a good value as it has the same transaxle and clutch as most of the Patriot models. Engine choice aside, is the overall build quality that much lower than the Patriots? Is there something that I am missing in this analysis? What else are you getting for that $2-3k? Thanks!
