GrowinWeeds
- Apr 16, 2015
- 23
This is on older Stihl FS85 brushcutter, but any replacement's OK, if it works.
Anyone found a good replacement plug wire, metal CONNECTOR tip [?female terminal] (guess style that “crimps" on outside of wire), w/o buying new wire & boot for this or similar equipment?
(Pic) Orig. has only a 1/4“ long, right-angle piece of wire that punches through plug wire (in one side, out other).
No “crimping” feature (like most auto or lawnmower plug wires) or anything securing the contact tip TO the plug wire outer covering.
The (coiled) part of terminal pulls off of, or -OUT- of the plug wire, just by removing boot.
The OEM (coiled) plug connector is v. hard to get off of plug (no rust/ gunk). Even w/ -just- the plug & tip laying on a bench.
The OEM design, it's V. hard to work the boot off the plug (snaking a bit of wire out of boot) w/o the unsecured 1/4" long "prong" pulling out of wire.
Thanks.
Thanks.
