ahdofu88
Hello,
On my gas trimmer if I were to let the engine run at idle for a while, at some point it will refuse to pick up speed when I pull on the throttle. It bogs down and dies. However I have noticed that removing the gas cap, fixes the issue. I thought perhaps the check valve was the issue but replacing the check valve did not solve the issue. Next was the carb itself and the fuel lines so I ended up replacing the carb, fuel lines and the filter. That did not do it either. Does anyone has any ideas what might be wrong?
Thanks,
Matt
Thanks,
Matt
