For that to happen & the mower not to run in circles then both lap bars would need to be out of adjustment by the same amountRecheck your owners manual. There should be instructions on how to adjust ( balance ) your forward movement using the lap bars. It's possible your not getting lap bars to the the full forward position.
Chances of winning the lottery would be better than that happening
Belt installed wrong is very high
Belt running between the pulleys & fans is very likely
Belt running on the wrong side of the tensioning pulley is also high
On some I have even seen the tension pulley on the wrong ( pull side ) run of the belt
But I have never seen a ZTR where bith lap bars went out f adjustment by the same amount all by themselves
I have seen them where the owner had "tightened" the controls & made a mess but never one that does it all by itself .
In any case I did ask tbmmbt to do a simple task , take a photo & post it so we can see what is going on.
So until he does what was asked of him ( assuming he is male ) then I am out of here
The rest of you can keep on adding your best guesses but have a good read of the post & the problem then think about what you type .
Nothing posted to date is factually wrong but none of then would cause BOTH sides to run slow in forward
