Firstly as others have said , but I will say it again
The warranty covers defects in materials &/or assembly so it covers the steel failing , a weld failing, a weld not being there, missing parts or bracket welded in the wrong position
All if these would manifest themselves in the first few hours of use
It does not cover misuse , abuse or failure to carry out proper maintenance
Next , lifetime is a meaningless term.
Legally it would mean the design service life and that would be for the shortest major part.
So if the transmission has a designed service life of 1000 hours ( K46 for example ) then 1000 hours is the life time of the mower.
If you payed extra for the extended warranty then you have been legally scammed .
Now as to your deck.
That is not a sudden failure
That crack has been there for a very long time slowly growing longer , you just failed to notice it till leaves & clippings started to stream out of it .
It was caused by excessive vibrations and excessive vibrations are a user abuse situation because they originate from some thing being out of balance which is usually a bent , broken or very dull blade .
If the mower was serviced by a competiant technician then they would have noticed the excessive vibrations and corrected the situation
If you have done your own servicing and have failed to notice the excessive vibrations then that is not Husqvarna's fault that is your fault for trying to do some thing you do not have the knowledge or experience to do .
FWIW I have just replaced an engine on a mower where the customer thought maintaining his mower was just a case of installing a maintenance kit annually so his ignorance just cost him $ 3500 .
Any reasonable welder can patch that deck then you need to paint it on the top .
After that you need to work out what is causing the vibrations and correct that
I could fairly safely bet that the holes in the mounting arms have been flogged out oval as well.
Sorry to hear about your failed deck but it is not Husqvarna's problem it is yours
You can spend another $ 2,000 and have a metallurgical inspecting & testing company do a report on it .
However I am fairly sure it will just confirm what I have said .
I did this sort of stuff after graduating as a metallurgist back in 72 .
It was extremely rare to come across a failure due to materials faults other than a lower grade of material being used.
However in your case there are two ( if not more ) cheaper variations of that mower made fr other brands that use cheaper & thinner steel for the deck pressing so again it will come down to owner abuse .
