FarmForce
I bought a new HRX217VKA in July and it must have been built on a Monday ... right from the beginning the valve cover leaked oil. I fixed this myself because it was easy. At the same time I also checked the valve clearance and both valves were at 9 thousands (spec is 8 to 12 thousands) so well within spec. The engine right from the beginning develops a noticeable valve train noise that doesn't start until the engine has been running for 15 minutes or longer, so not until it is fully warmed up. The engine starts quiet on cold start and runs fully quiet for some time, but then after 15 minutes the tapping is starting lightly and gets a little louder; then stays as long as I mow (about two hours). I am sure it's not the valve clearance as I checked it when I resealed the valve cover. It must be something in the valve drive train. I don't think these K6 version engines have the valvetrain belt anymore and the valve train might be driven by gears. This would make a little sense because gear-driven cams can also develop noise from the drive gears if they are not gapped correctly ( Harley had this in the Evo engine). My old GCV160 was dead silent, but this new GCV200 is noisy.
Anyone else experienced this? Any comments or advice? Thanks!!
