Briggs intek backfires at full throttle and surge at low.
Iowa900
  • / Briggs intek backfires at full throttle and surge at low.
Hello everyone. Have a 23 hp b&s intek. Was mowing the other day. All the sudden I started to get a back fire through the exhaust. It has 164 hours. Changed the plugs fuel filter and air filter and no change. Compression was 128 and 125 a side. I’ve read camshaft horror stories. I’m hoping it’s not. Seems to surge at low idle now. Any ideas or places to start? I’d appreciate anything you guys can throw my way.
Iowa900
Also I can take off the left side park plug wire and it runs really rough like on the verge of dying but it stays running. If I take off the right nothing changes other than the back fire seems to disappear.
Close the choke 90% closed. Does it smooth out?
Clean the cylinder cooling fins. Neglect this yearly and you will eventually get some engine damage.
Spray flammable spray around carb and intake pipes slash flanges. If the engine smooths out you have a vacuum leak.
Iowa900
Yes if I close the choke it smooths out. I’ll be sure to check the fins. I’ll also check for leaks!
Clean the fins first. This is not you main issue but needs to be done yearly. Clean as in CLEAN.
You have a fuel delivery issue.
1.Remove and flush out fuel tank.
2.Clean the carb internally with carb spray, compressed air and a jet cleaner of your choice. Make sure you have good fuel flow at carb.
Some carbs have welch plugs that cover internal carb passage ways.
The backfiring is unburned fuel igniting in the muffler
Remove the blower housing and remove the kill wires form the coils
Problem goes away = failed diodes
If the problem stays then swap the coils left right
Problem moves to other side = bad coil
Problem stays on same side = carb or valve problem
Iowa900
Awesome guys I’ll get to checking these out. Hopefully it’s nothing major.
Iowa900
Anyone know of a good place to order a coil for this? Model number is 4455 77 1187 B . Not bringing anything up. Any help or a website to try. Thanks
Model number needs looked at. Can't pull anything up with the model number you posted.
No problem finding 445577-1187-B1; just got to be formatted correctly. The current ignition coil is 592846.
