The Chairman
- Aug 9, 2018
- 171
Two options then...
Option #1) Fix the flat...
Option #2) Use slime
I worked as a mechanic for thirty years with half of those years with Goodyear Tire and Rubber. The smaller the tire, the more difficult they can be. While I would never use fix-a-flat, and especially not in a passenger car or truck tire, I don't mind using slime on turf tires.
- over-inflate the tire a bit and put it in a tub of water to find the leak.
- Don't forget to mark it well with a crayon
- Deflate tire
- Break beads on both sides of the tire from the rim
- Making sure the opposite bead slides into the "drop down", carefully pry the beads off of the tire on the same side
- Cussing is optional
- Buff, glue and patch the hole
- Reinstall and inflate tire
- Go to the store and buy Slime
- Deflate tire
- Pump in the required amount of slime
- Inflate tire and go for a ride to spread slime
- No cussing needed
- But a Margarita would be nice!
