Looking for opinions on the best small engines out there, new or old, up to 30hp for use in riding mowers. Please include any model numbers or the application it was installed into if possible. If the engine is bulletproof, Im listening, enlighten me
Briggs I/C (which are similar to old inteks, I think)engines are pretty good. I had one fire right up after sitting for 10 years. New oil and fuel of course.
But the truth is, everyone has had different experiences with engines and engine manufacturers, one guy might recommend a Intek engine over a Kohler Courage, someone else might like the Courage over a intek.
I would prefer equipment with a Kawasaki engine, because I have a Kawsaki horizontal shaft engine that has been running for 20 years. Only new p piston rings.original crank,cam and rod. And no major problems.
The Briggs L-head would be my choice, simple and reliable plus parts are reasonably priced and readily available. Trouble is the last of those were built years ago so any in service are well past the best before date.
Best engine out there was the Tecumseh SnowKing engine. Sorry it won’t work in a tractor, but you asked for the best engine. Even though Tecumseh has been out of business for 10+ years, there are still thousands of these units powering blowers all over the country.
