my87csx481
- May 28, 2019
- Threads
- 2
- 27
I am going to try "something". Just not sure exactly what.
Is this more about mass, or rigidity? You mentioned 3/8" thick....but how wide? 3/8 square?
I was thinking I could get some square tube stock, the stuff that has the holes in it already. Maybe 1" square....but I'll have to check clearance (above, and around). But this will weigh significantly less than a 1 x 3/8 x 40 piece of flat stock (I think).
If I went with the shorter (~10") pieces, what about putting a small piece of plastic, or rubber, in between the brace and the deck (just in the middle of the 10" brace)? To force the brace to flex a bit, and put pressure at the center of the 10" length. Is this worth trying? Before drilling the hole, and putting a third bolt in the middle?
I'm really hesitant to drill more holes in the deck (for now). I really miss having access to welders, and milling machines, and lathes (I used to be a machinist).
