reddragon
you know.....black bart is right.....you need that cooler pulling fresh air and pushing the heat into fresh air.....an air cooled engine isnt going to like extra heat added to the mix at all...if you had the cooler behind the grill [ i know its hard because of the hood flips up] then ducted the heated air to the side so that it has nothing to do with the engine cooling...or at least duct it where it is so the heat exits the engine compartment :frown:
