Chainsaw recommendation
Kimbo
Hey all,
Looking for recommendations on a homeowner chainsaw to be used for cutting firewood and storm cleanup.
I'd like to stick with Stihl, Echo, or Husqvarna, preferably under $300. What bar length and CCs should I consider?
Property details, 1 acre heavily wooded (oak).
TIA
cpurvis
You can cut some big trees with a 16" bar.
Husqvarna 455 Rancher. I think that's a current model. Stihl, Echo, Johnsred and Dolmar are good, too.
Get 50 cc or bigger.
tom3
One that really impressed me was an Echo, real slick powerful machine. Just felt and sounded like quality. That was some years ago. Told my son about it - so he went out and bought a Jonsered. Didn't like it from day one.
primerbulb120
I am usually the first to recommend Husqvarna, but I'd stay away from their homeowner saws. I have a friend who owns one, and he's had nothing but issues from day one.
I would go with a Stihl. Both Stihl and Echo are quality units, but the Echo engines are ridiculously restricted to reduce exhaust emissions. The Stihls run cooler and have more power.
mechanic mark
Still ms251 wood boss 18” bar at ace hardware for around $330,one son has husqvarna 455 rancher $450 at Lowe’s other son has echo Timberwolf was a returned new saw at Home Depot for $300 both have 20” bars
tom3
And we've some some serious cutting with a 14 inch bar/chain. 14 or 16 would do about anything and some easier to maintain than the bigger stuff. And I'll add, if you're new to saws, don't use a chain too long. Can sharpen and run several cycles but those chains do stretch and wear out the drive sprockets. A brand new chain is a thing of beauty cutting wise.
Darryl G
I think it's a bad idea to recommend a chainsaw to someone on a forum like this with the amount of info we've been given.
You should get a saw that you can handle SAFELY given your size, weight, strength and level of experience. And if you're inexperienced you should get trained in the proper use as well as purchase proper safety gear, if you don't already have it.
I suggest that you go to a professional power equipment dealer (not a big box store) and let them size you up and see what they recommend.
When it comes to chainsaws, you can not spend enough.
One of the few products where the more you spend the better the product.
I still have our Stihl Farm Boss bought in 1984 and regularly lend it out to customers whose saws are going to take a long time to repair.
They are amazed and regularly want to buy it then are aghast when I tell them it is still made & available for the same "weeks wages" as it was back in 1984.
But they will not pay the now $ 1400 ( because wages have gone up ) for a new one.
Lots and lots of junk saws out there including the ones from big brands like Stihl & Husqvarna who are forced to sell garbage to get people to come into their shops.
Echo is almost non existent down here as the franchise agent was fairly well pathetic and is now Briggs & Stratton who have their own line of rubbish Chinese chainsaws.
So I only see 20 year old Echos which were top line saws in their day.
As others have mentioned, around 50cc is where you should be looking.
A member of our emergency services gave me a tip decades ago which I have found to be very good.
That is to fit a smaller bar than the standard bar so my Farm boss wears a 16" bar & not the 18" it came standard with.
Then buy 3 chains for that size bar and whenever you refill the fuel tank, swap the chain for a new sharp one & invert the bar.
My saw still has it's original bar.
When the 3 chains have been sharpened to their limit, buy a new sprocket & 3 new chains.
We have nothing other than wood heaters in our home & I have been cutting Aussie hardwoods with it since 1984, around 3 ton a year for us and another 20 or so for pensioners from roadside wind fall.
A good strong saw will have a cutting tooth every second link in the chain.
A cheap underpowered saw will have a cutter every third or fourth link.
As also mentioned, a chain saw is the most dangerous tool the average home owner will ever touch so a short course at one of you community / trade schools before you buy your saw will not be a waste of either time nor money.
It will allow you to decide what type, weight & size of saw will suit you best and how to properly maintain your saw.
A thousand dollars might sound like a lot but over a 50 year life span is a slab of beer a year which is what using your neighbours saw will cost.
A good saw will have an engine that is complete and fitted into the fuel tank.
A cheap saw the fuel tank will be the lower half of the crankcase.
helomech
I have a 16" bar echo, and a 20 inch bar Stihl, the stihl barely ever gets used. I have cut some huge trees with the 16" bar echo. Unless you are cutting extremely large trees a good 16" bar will do it. I have a bunch of echo equipment and have not had any issues with any of them.
7394
My Echo has a 16" bar as well. It does everything I've needed to do as homeowner w/lots of trees.
