I have a 135212 5hp on a chipper, and am not getting spark.
I ohmed out the coil and it was low, so I ordered a new coil.
Now the part that has me confused. I also have continuity between the kill wire terminal and the frame of the coil on both old and new coils, so the termial is a ground as soon as I bolt on the coil. I've tried cranking it with the wire connected and disconnected, and still no spark.
I set air gap to .013 and even tried .010 but still no spark.
What am I doing wrong?
Now the next. The kill wire attaches to the throttle control and provides a ground when moved to the off position, but the second wire coming out of the plug is screwed to the carb. Wouldn't this ground out the kill terminal all the time?
