Mkala
Hello everyone,
First I'm new here, I try to read basics thing but if I do something wrong let me know. I used forum a lot when I was younger, but not so many since...
If this place is strictly reserved to mower let me know I remove my thread...
I like working on small engines, manly doing maintenance on my stuff or repairing older stuff (or helping others).
Main goal is turning wrenches, as Mustie1 says on videos
because I like doing this in my free time.
This week I picked up a used not working generator for few bucks. It has the generator capacitor that fail (easy fix) and generous oil leak, crankcase gasket seem the cause (and a few other not interesting issues for now
But my main problem is : I can't identify the engine ! Can someone help me ?
What I now (almost nothing) :
2100-2400w Generator (so I expect 5-6hp engine ?)
Obviously an inclined OHV design
It's not a GX clone (carburetor bolts are at same level)
Only makings I see on case are : "*04040035*" .Not sure of start and end symbol, numbers I am.
Huazhong carburetor (no other markings)
Torch F6RTC spark plug. So if it's the original one some kind of chinese engine I imagine ?
I post some pictures with some measurements. Let me know if you want any other picture, any measurement.
Case marking
Cast flywheel (plastic fan on Honda and clones usually) and strange starting cup (no holes, but indents)
4 screw rewind (3 on most engines)
Some reinforcements in block ?
Strange governor arm and governor fixation. It dows not pinch governor shaft, but it hold with two nuts (top and bottom)
Strange two piece assembly for rocker cover. Was not able to remove the other part to see the rocker, don't want to break more gasket before identifying the engine.
Was not able to remove crankcase cover, it's holding on motor shaft (don't know what to do ?)
Any help and advices greatly appreciated ! If something is not clear let me know english is not my language.
Thanks !
Case marking
Thanks !
