Also the kill switch.........
That is the brake mechanism. When you pull back on the brake bail on the handle, it will release the brake pad so you can start the engine.
See EXAMPLES of Briggs ENGINE numbers, try looking on the ENGINE itself around the spark-plug area, could be hidden by dirt
View attachment 41830...View attachment 41831...View attachment 41832
click to enlarge
numbers thank youhow does it work if it does have any moving parts? how would someone if it was broken
