WHAT IS THE BEST PUSH MOWER?
Stephen0523
Hi all. WHAT IS THE BEST PUSH MOWER? Price is no object.
Thanks in advance
Stephen
Two-Stroke
1977 Lawn-Boy model 7266 (or other Lawn-Boy from the 1970s)
It's light, powerful and will last decades if maintained properly -- and that's not too hard. :wink:
And parts are available.
SirJohn
If I recall, there were some old 214 series hondas that were pretty legendary as well. If you want current best brand new models, and are looking at 21" non propelled models, I would say probably either the Honda HRC216PDA or the Toro commercial 22155.
reynoldston
I am going to vote for Toro. I have two of them both over 30 years old and still going strong.
rekees
Thanks in advance
Stephen
Consumer Reports rates the Honda HRX2172HXA as the best self propelled.
SirJohn
I just thought I would add something. Best can be a relative term. You need to consider what would be best for your needs. Are you doing commercial mowing where you need ridiculous durability and longevity? If not, it may be better to look at some lower price models. There may be features on the consumer grade models that are handy as a homeowner that aren't found on a commercial grade model. Some people may need a lighter weight and commercial models tend to be heavier and if they are only using them for basic residential duty and giving proper maintenance, a residential model will last a good many years.
First step is to figure out your needs. What is the area that is to be mowed and how frequently? Do you need self-propelled? I know in my case a self-propelled wasn't feasible given that I have a small yard with a lot of tight areas with obstacles that would require a lot of pushing and pulling back on the mower. The size and weight of self-propelled and the extra hassle of having to constantly engage and dis-engage the drive meant that in my case, the standard push mower was a better option.
LandN
Thanks in advance
Stephen
the absolute best mower beyond the shadow of a doubt is the mower that YOU decided on AFTER your research,and comparison shopping,and finding YOUR needs of a mower to do the job that it's intended for.....commercial or homeowner mower? rwd or fwd? propelled or not? dealer or box store? how the mower fits you? rear bagger or side bagger? etc. etc. by doing a lot of homework/legwork and getting ideas on this forum will you THEN be able to go and buy the BEST mower for YOU. Everybody has different needs and requirements of a mower in different parts of the USA.just a side note here,It took me 6 months to end up with the BEST snowblower:biggrin: good luck in your journey
robert
Neighbor has the Honda with the 'plastic' deck, has not changed the oil in 6 years, machine runs perfectly AND the synthetic deck is in better shape than any metal deck I have ever seen-plus its alot quieter than any other I have listened to.
JDgreen
Thanks in advance
Stephen
One that is PAID FOR, STARTS EASILY, CUTS WELL, and best of all, RELIABLE. When you say price is no object, you are wrong. I doubt if anyone here can buy a mower and not be concerned about price. I am sure you could have a shop build your dream push mower, mine would have a 36 inch cut, an aluminum deck, a 20 hp Onan, and be able to run for hours on a gallon of fuel and be a true zero turn. And pull me behind on an air conditioned sulky while I watch dirty movies on a big screen...yes, someone would be willing to build me one if I wanted to pay the price. GET REAL.
JDgreen
Has not changed the oil in 6 years...anybody who would treat a mower like that is a MORON.
