HughDaHand
It's normal for these 2 blade decks to be hung a little diagonally. It's a little trick to let the blades have a little bit of overlap while driving straight.
I did see it, but it's hard to see much of value probably better pics of the deck and the "hangers" on the mower frame when you drop the deck ..BE SURE TO TAKE MANY, MANY, PICS of your disassembly .. they will be valuable later as you reassemble !!
According to the diagrams, the brackets that are bolted to the deck are oriented correctly. However it seems as if I reversed the right rear deck bracket so that it was biased more towards the left that the hangers would be aligned much better.
These are some sub-par photos today, but that's what I have for now. Also, my new Gator blades came in. Good stuff as I am accustomed to. I can't say for certain that they cut better but it would seem as if they would create a better turbulent swirl with the aggressive fins.
I would reverse the RIGHT side hanger adjuster so the cotter pin hole faces outboard, even if a little amount of bending of the bracket is necessary, I think you're gonna have to experiment with it ....... Boo
Tried that and the alignment was even more terrible, to the point of almost not fitting at all and binding.
If I swap the bracket that's bolted to the deck it might be more likely to be possible.
If you notice in the front mount on the frame, both of the cotter pins face towards the left, however.
