SidecarFlip
- Aug 21, 2018
- 282
be prepared to pay big bucks for a new clutch assembly, they aren't a cheap date by long shot.
On my cub, I managed to sever one of the wires going to the clutch so I took it off the pto end of the motor and got in on the bench and found out I had just enough wire left to attach a solder on butt connector and call ot good (did that on both leads). Then I added female butt connectors to the leads from the clutch switch and made doubly sure the wires were tucked up next to the frame, run in plastic convoluted tubing and securely zip tied to any and all tie points along the frame. No trouble since.
I was adverse to buying a new clutch in as much as a new one is around 150 bucks. I have other priorities to spend my money on.
Unless you spend an inordinate amount of time switching the clutch on and off, the air gap won't change that much. I have 7 years on my clutch and it's still just fine. engages hard and quick and disengages the same.
