Andy in Ottawa
- Aug 31, 2018
- Threads
- 1
- 5
For many years, I had trouble with my B&S mower, having to start on low throttle and increase gently as it warmed up because if I put it full on, it would sound hollow, lose power and die. Then, three years ago, a friend took the carb apart and cleaned it. It was like magic! For the last three wonderful years, it has started first time (even in spring) and worked perfectly. Until TODAY, that is. For the first time since my friend fixed it, it ran out of gas. Now, the problem is back, and it's worse than before. It will usually start if I prime it, but it only runs for a few seconds, and I can't get it to full throttle to actually mow without it dying again. So, I want to know, "what happened"?
I have heard a story that if you let an engine run out of fuel, then it sucks in the debris from the bottom of the tank, and this gums up the carb. It fits the evidence, but I have a VERY HARD time trying to imagine how the fuel intake would work, that it would carefully ignore the gunk for three years, and then suck it all in when the fuel runs out. It doesn't "ring true" as it were. Either it sucks fuel from the bottom, or it doesn't. It's not going to take fuel from the middle normally, but bottom-feed if you dare to let it run low on gas.
It seems more likely to me that there's an air bubble in the line, or something, that's stopping the intake from getting a full flow of fuel. If so, how can I avoid it or fix it?
Are either of the above true, or could it be something else? Can I do anything other than take apart and clean the carb like my friend did?
Do the rest of you always avoid letting your mowers run out of fuel to get around this problem? It doesn't say that in the instructions, but it seems to turn a fully functional lawn mower into a brick. (I am careful to check the content of my can of fuel, by the way, and don't pour the last bit into the mower's tank, so the fuel should be pure, and I always use premium fuel.)
I appreciate any comments that experts can offer.
