- Nov 29, 2014
- Threads
- 65
- 24,995
The chips are just a Hall effect bridge,
You seem to know your way around electrics so it should make sense to you.
They used to be in a stand alone unit but now they are on a chip hard wired into the coil which now becomes a "Module" at 4 times the price.
Some also have a delay so the same crank & flywheel can be used on a lot of different mowers.
