Mastiffman
Good day fellas!
I have a Kaw FC420V that needs a rod which I'm getting ready to replace and I'm curious if I can use a Rod from any FC420V or does it have match the last 4 revision(?) letters of the model. In this case BS02.
I can't seem to find any used ones on the bay. I would rather not drop a full $65+ on a new Rod if not a full rebuild of the engine. Just going to replace the Rod if the crank journal is fine as well as de-carbon it and do a valve and gov/carb adjust (Surges at idle).
Thanks in advance.
Thanks in advance.
