- Nov 29, 2014
- 24,995
Yes
It is electric so you can get a broken wire that touches some of the time.
Inside the Module is a small Hall effect chip which replaces the points and these are very amperage sensative some cheap multimeters can actually fry them.
You can et corrosion on the kill wire and a bad ground through the mounting bolts which is what needs to be cleaned
The rest does not matter.
