hrdman2luv
Just got this older (green) Craftsman, with an 18hp OHV briggs, 31P7770299E1 (has oil filter) Finally got it to crank. But man O man O man, when it did, it blew the PCV tube off the breather, and soaked the side of the engine and the front tire with oil.
I had checked to see if it had oil in it first, but didn't really look at the level. Well, it had too much in it. Way too much. Like an inch above the full mark. So, I sucked some if out, down to the right level, and cranked her up again. And It was still coming out like crazy.
Any other hints before I remove the head? I'm thinking it's a head gasket. But would like some feed back first.
