16.5 Hp Lawn Tractor runs only on (nearly) full choke
Chartman
I have an MTD lawn tractor (pretty old) with a B & S Model: 42A707
Type: 123801 engine (Opposed L Head Twin Cylinder).
It was running poorly, so I pulled the carburetor and did a complete rebuild;
I replaced all the part that were included in the rebuild kit except for the Welsh Plug,
which seemed tricky and I didn't see what replacing it would do.
I cleaned out all of the passages with aerosol carb cleaner and everything seemed in great shape.
I reinstalled the carb and fired up the engine.
It started right up and ran great, unless I tried to open the choke.
It seemed to me that it must be either starved for fuel on the carburetor intake,
or was leaking air into the cylinders downstream of the carburetor.
The carburetor rebuild went so well you would have a hard time convincing me (though it wouldn't be impossible)
that there was a clogged fuel passage somewhere in it.
On the other hand, I sprayed starter fluid around the carb, intake manifold connection points, etc while it was running
to see if it caused the engine to sputter, but it had no effect.
I considered that the head gaskets might be leaking air, so I tightened those bolts.
They were "not particularly tight" (pardon my technical language) when I got to them. Some were looser than others.
I tightened them all. I did not use a torque wrench. I didn't know what the proper torque would be.
I let the engine run for about ten minutes and it sounded great the whole time (with the choke on almost full).
It was not, however, under load operating the blades or the wheel drive.
I am pretty much at a loss now for what to do.
I suppose I can re-assemble the tractor and just (try to) use it while leaving the choke mostly on full.
That somehow seems wrong to me.
Anyone have some advice?
I have read that closing the choke and operating the machine causes lean fuel/air and overheating. Probably gotta do the carb, again. Or, seek professional help with the Welsh plug.
Thanks, Pythons37.
I have ordered a pair of head gaskets and will try that first.
I should probably also talk to a local small engine repair shop about the Welsh plug.
Chartman
Probably didn't get a orifice cleaned out good enough. If it runs with the choke in, than that means it is getting to much air vs fuel with it open. Pulling the choke restricts the air, and makes the air/fuel mixture correct. Or at least close to correct. Go through the carb again.
Go here http://outdoorpowerinfo.com/repairs/#id_briggs
Download the two threads on the opposed twin carb then reflect upon what you did with yours
They are a particularly tricky carb to work on & having the fuel pump combined does not make them any easier.
The welch plug you did not remove accesses the idle mixing chamber which one will assume is working on your mower.
Thank you, helomech.
I really thought that everything in the carb was cleaned out well when I worked on it at the bench.
The prevailing opinion, however, seems to be that there is still a carb problem.
The tractor is still "open", so it will be a small deal to pull the carburetor again.
I appreciate your input!
Hi bertsmobile1,
That is a FABULOUS link you referenced.
I can't thank you enough!
I am looking forward to pulling the carburetor again and going through it with a renewed understanding of how the ports should be connected,
and where there may be blockages that need to be addressed.
I may not get to it for a few days, but I will certainly report back on what I find after I do.
...and thanks to everyone who responded.
Chartman
I had a boat I fought all the time. Thought I cleaned everything and it still ran like crap. Brought it to a mechanic and he cleaned the carb and it was all good.
Hi bertsmobile1,
Chartman
DOn't thank me I got it from some one here when they were talking about cross refferences for belts but you will have to go to the home page & navigate to it.
Yes a very good site, a lot of work has gone into it
