turbofiat124
- Mar 23, 2011
- Threads
- 83
- 288
Sorry I have not had a chance to look at this mower since the other day. I've been working night shifts.
I work with a guy works on mowers and saw him yesterday. I asked him if it were possible the shaft on one of the spindles could bend but not actually break the pot metal legs on the housing and he says he has seen that happen before. My assumption was the housing was made of such weak porous material that the housing would break long before the shaft could possibly bend.
Another thing he told me to do when checking for a bent spindles is to engage the blades (not when the mower is running of course). He says with the belt disengaged, the blades may appear to line up correctly but when the blades are engaged the belt tension will move the spindle (if the feet around broken).
It looks to me like the right hand side blade is the culprit. I'll take a look this weekend and see what I find.
