Engine is a Kawasaki 18 hp v twin with a heck of a leak.  Here is the original thread explaining it
http://www.lawnmowerforum.com/showthread.php/39911-FH531V-18-hp-v-twin-leaking-tons-of-oil
So what I found, the crankshaft exits the bottom of the engine to hold the main drive pulley and the pto. The shaft diameter at the oil seal is about 1 1/4". Approx 1/16" below where the seal is the diameter drops down to 1". Do, after the engine runs for about 15-20 minutes, something allows the crankshaft move up vertically. This moves the area that the hits down to the 1" diameter and then the oil begins running out.
Now I can't imagine what is allowing The crankshaft to move upward but it does. There is evidence of this as the drive pulley which is on the crankshaft is located just below a flat piece in the frame. When the engine is cool you can feel approximately 1/8 to 1/4 inch between the pulley and the bottom of the frame. But after you take off the pto and drive pulley, you can see where the crank pulls the pulley up and hits the frame as it has all the paint word off.
Now it appears the crank and cases uses no bearings but looks like there are bushings case into the case halves. Then the engine part pictures shows two snap rings, one in the bottom of the lower half and one in the top of the lower case.
So what do you all think could have caused this and any fix? Or has anyone else ever seen of the same type of thing.
